Could you help me with finding the right capacitors please ???
Zilla
So i brought this sexy broken 780TI for a steal and I know a small amount about electronics so i am hoping to fix it but i need some help first.
I would like to confirm what the parts are, I think the capacitors that are broken are 16v 271uf ? but if you could post a uk ebay link for the parts that would help?
Any info on this subject would help 🙂 here are some pics and thank you so much for any input ❤️
IMG_20210226_012114.jpgIMG_20210226_012152.jpgIMG_20210226_012106.jpgs-l1600 (1).jpgs-l1600 (2).jpg
38 minutes ago, Glenwing said:
It is 270 µF, 16 V. The "271" means 27 × 101, or 270.
Should use some calipers to get the diameter, but looks like probably 8 mm. https://www.digikey.com/en/products/detail/united-chemi-con/APSG160ELL271MH06S/3528485
I could kiss you sir xxxxxxxxxxxxxxxxxxxxxxx thank you so much
What does the fp10k mean? do i need to match that spec/number? and what does the 43Az mean? also some random ones are labeled 43Bz, does that matter?
What would be the % chance this will fix the card? and what else would this damage brake?
Should i replace all the 16v caps? and the 3v caps? none of the 3v caps look damaged fyi
The 16v caps are 6.5mm wide so would this link work?
16v 270uf 8mm https://bit.ly/3aSXW8z but i rly need 6.5mm
3v 820uf https://bit.ly/3bJApWO is it safe to use a higher rated voltage cap for the 3v 820uf caps?
Sorry for been a noob and tons of questions but i will post pics and updates 🙂
Maybe this is the wrong forum for this stuff.
