Help when I power my pc fans spin for a while then nothing
Whenever I turn on my PC, my fans spin for a good 20-25 seconds with no video output and then they shut off for 2 or so seconds then the process repeats.
specs:
cpu:ryzen 5 2600
gpu: rtx 2060
mobo: ASRock b250m pro4
ram:16 gb 8x2 (usually running dual channel)
Solutions i have tried:
replacing mobo (inspected cpu)
trying turning it on with every possible ram position including with no ram
making sure everything is plugged in everywhere
turning on without gpu, ssd, ram
I have not been able to verify that my ram works still but I want to see if its a likely candidate before buying more.
right before this happened i got the error 0xe0434352 at location 0x00000000775546d2  when shutting my pc down. When I powered it back on I found out that only 8 gb of my ram was being shown so I shut down made sure both sticks of ram were installed, when I turned it on only the fans spun.
Any suggestions would be appreciated.
This is gonna sound kinda dickish, but have you tried a different cord..... My trusty faithful HDMI quit on me about a month back without any warning. Mind you, it's like 8-10 years old at the time. The other thing to consider: are you overocking? What speed is your memory running at? I've gotten overocks that don't crash the system, but also don't give display output.
i have tried different coords and the memory speed is 2400.
I would recommend clearing CMOS (take out button cell battery for a few seconds, then put it back in) and having it try to post running bare bone stock settings... If still nothing happens, then it might be the RAM. I would suggest then running it with each stick separately to see if you have a bad stick. If both sticks work, try re-seating the CPU.
i have tried the one stick test to no avail, when i switched the mobo I also reseated the cpu and mostly everything but i will try the battery.
Both sticks on their own didn't have it POST? Did you try them in different RAM slots systematically to see if a RAM slot wasn't working?
i tried every possible configuration of ram without POST.
Just now, BiotechBen said:
Have you tried re-seating the CPU? (Taking out and putting back in)
yes i swapped mobo in the process i did reseat my cpu
20 minutes ago, BiotechBen said:
and none of the things fixed it?
no the only difference between tests were the color of the rgb fans i have but they seem toi have no corolation with anything
I used an identicle motherboard (ASRock b450m pro4) for my build and to troubleshoot, ill will thoroughly inspect my cpu again.
specs:
cpu:ryzen 5 2600
gpu: rtx 2060
tried with a verified working stick of ram
Resetting CMOS
reseating everything
right before this happened i got the error 0xe0434352 at location 0x00000000775546d2  when shutting my pc down. When I powered it back on I found out that only 8 gb of my ram was being shown so I shut down made sure both sticks of ram were installed, when I turned it on only the fans spun and it was bootlooping after 20 or so seconds.
specs:
cpu:ryzen 5 2600
gpu: rtx 2060
Resetting CMOS
Which motherboard did you test?
hi, im renata bliss and am ur freestyle dance teacher
