Low FPS on a computer I built for a friend
Swimsam1
Specs
motherboard: ASRock Bm450M
Processor: Ryzen 5 1600 6 core
graphics Card: previously was a scammed eBay card that would constantly crash his computer (amd sapphire) but now is a
GTX 1050 ti single fan
Memory: one stick of 16gb Ddr4 ram by hyperX
power supply: 650 watt
hard drive: sea gate 250 gbs
no solid state drive.
my friends abs are are trying to play 7 days to die but the computer I built for him doesn’t have good FPS please help!!!
1 minute ago, Swimsam1 said:
Specs
FPS average?
I think your pc is held back (fps wise) because it has 1 stick of ram.
5 minutes ago, Swimsam1 said:
Specs
1050Ti, Single-channel RAM - this doesn't exactly help performance.
What games are your friend playing? What resolution? What FPS is he getting now?
7 minutes ago, Swimsam1 said:
Specs
its the ram. Add a second stick of the same speed
geometry is hard
b550 > x570
Well what fps ARE you getting? What type of preformance are you expecting?
There are many things wrong with this build.
Single channel with ryzen
250gb hdd is slow for texture loading.
but yet you have a 650watt PSU. So ethier you spent tons on you Power Supply or just had one laying around
What speed are you running your ram at?
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
Before his computer would crash now he is getting very low FPS do you think if I gave him two of my 8 gb sticks and took his 16 stick I would see a downgrade in performance myself? I have three sticks of 8gb ram two Corsair sticks and one hyperX
I think you should start with saying what resolution your friends plays in and what FPS he's getting.
did you uninstall the old drivers with ddu and install the new 1050ti ones?
geometry is hard
b550 > x570
No we did not
they would run in single channel, so yes
No we did not
thats the culprit (the single channel ram also kills your fps)
geometry is hard
b550 > x570
I’m very sorry I’m just trying to communicate and I understand the frustration my friend is very mad at me and I’m very disappointed in myself
No we did not
do you have ANY drivers installed?
System Specs
Peripherals
<Razer Mini>
Take your time, no rush.
The old ones should have been installed cause the amd control catalyst shows up
okay well
Uninstall the bad radeon drivers with DDU, then install the 1050ti ones in NVIDIAS website
Also tell your friend too not be rude, we have basically found the reason why the FPS is bad. Tell him to calm down and be patient.
Also a 2nd stick of RAM would help alot
geometry is hard
b550 > x570
1 minute ago, Downkey said:
okay well
Okay thank you guys so much!!!! Y’all are awesome
So to recap from what everyone is saying:
1.single channel ram is bad (get two sticks) and yes, you yourself will notice an fps drop if you put it in your own system.
2. uninstall bad drivers and install the lastest from NVIDIA'S website.
3. grab a beer
4. profit
3. grab a beer
4. profit
ayo he could be underage
also reinstalling the new drivers should come first
geometry is hard
b550 > x570
Ok so a couple things to start
What 650watt psu. Please give us the model.
One stick of ram on ryzen really hurts the performance
A gtx 1050ti isn't exactly a great gpu but 7days ran fine on my by now ancient hd 7870 fx 8320 system and the 1050ti is a bit better than that.
people people
stop acting like single channel RAM is the end of the world, it's only about... 10-20% perf difference at best?
i would recommend starting with DDU and reinstalling the latest drivers from nvidia's site
and do compare your results with people on youtube, see if it's expected behaviour or not at all
as sometimes low fps is just due to your hardware's capability and no amount of fixing will boost it
-sigh- feeling like I'm being too negative lately
And you still haven't answered the question...
F@H
GPD Win 2
Well, just DDU and install Nvidia drivers that should very likely fix the issue.
yeah, I agree, sure dual channel ram is preferable but the difference isn't that big, having the totally wrong drivers installed should have a much bigger impact on performance. 🤷🏼
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
