Insanely high IDLE CPU temps (Ryzen 5 3600)
5 minutes ago, TwoShoes said:I sent pictures of the settings I changed. I think I followed what you said. When I got my new CPU, I updated the bios to 3.3, which I know isn't the latest but is what was listed on the website next to my CPU. Should I attempt updating the BIOS again? This could fix some issues.
Updating the bios wouldn't hurt at all. Note: After updating it they recommend "After the system restarts, press [F2] to enter the BIOS setup utility during boot up. In Exit menu, please select "Load Default Settings" and press [Enter] to continue. Select "Exit Saving Changes" and press [Enter] to exit the BIOS setup utility. Now, the system is booting up with new BIOS."
After this you'll need to go back to BIOS again to reapply your XMP profile for your ram and anything else you want to change.
Personally the only changes I ever make in BIOS are:
Disable Spread Spectrum which given your sound issues you might want to re enable.
XMP profile for ram
Enable PBO
Customize my fans in HW Monitor tab
