Schiit magni not in uk
Janettebot
Hello. I have recently been considering getting the hifiman he-400i, however the amp I have been recommended (schiit magni) is unavailable in the uk. I am currently looking for alternatives to drive the he-400i, no dac required. Budget is £100 please help, thanks in advance.
I can't seem to find a decent description of those headphones. If a simple amp is what you need, a M-Audio or Behringer would be fine. With the Trump taxes still in place, you would end up paying quite a bit more than the US price, if sold in the UK. Again, I have no idea what those headphones need. I would assume onboard audio would struggle a bit, a decent sound card may be all you need. If you plug them into a TV or receiver, there is likely no need for one to begin with. Again, no idea on those headphones. I only use studio grade headphones.
They are 35ohm 93db sensitivity planar magnetic headphones if that helps, I only need an amp because the line out on my mobo will be fine for now.
If you are listening primarily on your PC, get a dedicated sound card from Creative or ASUS. 35 Ohms should not be an issue for those cards. Onboard audio should be fine as well but often lacks some clarity with more expensive headphones. If you want something portable, pretty much any brand name headphone amp will do just fine.
35 Ohms at 93db/mw is not that easy to drive well.
On 2/24/2021 at 9:46 AM, rice guru said:
I've heard the liquid spark recommended several times, should be a good one.
onboard can do it but they certainly benefit from an amp, I tested my he400i onboard
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
Driving well doesn’t mean to get it loud enough.
I know this
DAC S.M.S.L SU-9
