If I were to get a Raspberry PI 4 4GB, what Linux Operating System should I choose?
Solved by kelvinhall05,
You are going to be very limited by the arm architecture and relatively slow performance. If you need Linux, run it in a VM or off a USB.
Timotheus865 ·
Posted in CPUs, Motherboards, and Memory2 -
OhYou_ ·
Posted in Cases and Mods0 -
Echopanda187 ·
Posted in Peripherals3 -
Master PC ·
Posted in Cases and Mods1 -
2
2
1
5
