Search In
  • More options...
Find results that contain...
Find results in...
Why does android replace folders rather than merging them?
so i find it really odd that even with latest version android 10, we have this inconvenience. Is this a thing with android as a whole or custom ones like Realme UI? i find it hard to believe they can't implement such basic thing
i think Windows has since xp (maybe before but our first home pc back in 2003 was with that so i never used any earlier versions so not entirely sure). is there a good 3rd party file manager which supports it? but i wanna stick with stock ones
i never use 3rd party versions of anything on android unless it's really bad. I had to replace one folder which was an updates version anyway so not a loss and intentional by me but i had to skip many because some pics or files might have got removed
moving stuff around stuff will be easier if merging worked in android. I hope they bring it in future soon, my phone will get android 11 next month hoping for whole lots of improvement but it's unlikely this feature will come
btw raise to wake is also not working on phone and i can't find it in settings, after resetting it, i didn't get the option to enable it like before when i got my phone and had to file for a replacement.
PC Specs : Intel Core i5 7500 | Zotac GTX 750 Ti | MSI H110M PRO-VD | Hynix 16GB 2666MHz | 120GB Crucial BX500 | 1+2TB Seagate Barracuda 7200RPM | Circle 500W APFC PSU | Ant Esports ICE-211TG | 2x 120mm ARGB Case Fans (Front and Rear)
Peripherals : HP 22es 1080p IPS Monitor | Redragon M609 RGB Gaming Mouse | TVS EGold Bharat Mechanical Keyboard | Redgear Pro Wired Game Controller | F&D A110 2.1 Stereo Speakers | Dell 1TB Ext. HDD
TV : Sanyo 32" 1366x768 HD Ready TV (XT-32S7000H)
Phone : Realme C3 (4GB LPDDR4X RAM / 64 GB eMMC 5.1 ROM with Helio G70 CPU and Mali G52-MC2 GPU and additional 64GB Sandisk Ultra Class 10 UHS-1 SD Card)
No idea what you mean by "replacing folders", I never had my android devices "replace folders" that I know of...
F@H
Desktop: i7-5960X 4.4GHz, Noctua NH-D14, ASUS Rampage V, 32GB, RTX3080, 2TB NVMe SSD, 2x16TB HDD RAID0, Corsair HX1200, Thermaltake Overseer RX1, Samsung 4K curved 49" TV, 23" secondary
Mobile SFF rig: i9-9900K, Noctua NH-L9i, Asrock Z390 Phantom ITX-AC, 32GB, GTX1070, 2x1TB NVMe SSD RAID0, 2x5TB 2.5" HDD RAID0, Athena 500W Flex (Noctua fan), Custom 4.7l 3D printed case
Dell XPS 2 in 1 2019, 32GB, 1TB, 4K
GPD Win 2
it shows replace folder confirmation when i try to copy something from another location which has a folder with same name.
Can you tell me how i can re-enable raise to wake screen? didn't get the option when setting it up and can't find in settings as well
Maybe the new device probably came with newer firmware where they removed that function... anyway settings are manufacturer-specific, no idea where Mi would put it in their UI.
it shows replace folder confirmation when i try to copy something from another which has a folder with same name.
That will be a function of the file manager you use, probably don't want to use the usually crappy one provided with the manufacturer's system layer. The one I use (File manager +) asks to replace or merge.
F@H
GPD Win 2
2 minutes ago, Kilrah said:
The new device probably came with newer firmware where they removed that function...
well, it's the same phone and i got it pretty much on the launch and it has regularly received updates ever since, i mean of late it's been more less frequent but earlier it was like atleast 1 or 2 update month but now they only give an update in like 2 months or so.
well as i said earlier, i want to stick with stock one, because of it's simplicity and don't want the clutter of something duplicate (like 2 apps for literally same thing), it works and fine for most part, i would only look for an alternative if it was abysmal, i mean i don't even go to file manager much unless it's really needed (that too occasionally), i mainly use apps and don't even play single game for several months now even though i have many installed.
