Search In
  • More options...
Find results that contain...
Find results in...
Max safe voltage for 24x7 on Ryzen 5000
I am currently using my 5900x @4.7ghz all cores on 1.3v LLC4
Is it safe for long time usage?
I can do 4.6ghz on 1.18-1.2v as well, if necessary i can lower the voltages.
Thx 馃檪
聽 聽 聽 聽 CPU:Ryzen 5900x @ 4.6ghz all cores 1.18v
聽 聽 聽 聽 AIO:聽Corsair H150i 360mm
聽 聽 聽 聽 MB:Asus B550-E
聽 聽 聽 聽 MEM:聽64GB聽DDR4 Kingston Predator @ 3200 16-16-16-36
聽 聽 聽 聽 GPU:PNY RTX 3080 XRL8
聽 聽 聽 聽 CASE: Metallicgear Neo Qube + 5x Arctic F12
聽 聽 聽 聽 Storage:
聽 聽 聽 聽 聽2
x NVME Samsung 970 Evo Plus聽500 GB
聽 聽 聽 聽 聽1x聽SSD Crucial MX300 1 TB
聽 聽 聽 聽 PSU:Corsair HX1200i
聽聽聽聽聽聽聽 Monitor:聽Asus PG329Q
High LLC can kill too! Vdroop is good for longevity
You shouldn't be forcing an all core OC on to a Ryzen CPU at all. Its gaining you hardly any extra performance under heavy loads but is losing you a fair chunk of performance under light/single threaded loads.
The best thing you can do with any Zen 2 or 3 CPU is leave it alone.
Main Rig:-
Ryzen 7 3800X | Asus ROG Strix X570-F Gaming | 16GB Team Group Dark Pro 3600Mhz | Corsair MP600 1TB PCIe Gen 4 | Sapphire 5700 XT Pulse | Corsair H115i Platinum | WD Black 1TB | WD Green 4TB | EVGA SuperNOVA G3 650W | Asus TUF GT501 | Samsung C27HG70 1440p 144hz HDR FreeSync 2 | Windows 10 Pro X64 |
Server:-
