rt-ac88u Help me diagnose why my router intermittently shits itself.
Solved by Falcon1986,
Make note of any important settings, then try to reset the router to factory defaults through the web interface, not the hard reset method. Set up the router again from scratch.
Disable AiProtection and any other built-in security features. Leave the firewall active and set up your WiFi with as normal with WPA2/AES.
1
4
Yosh1 ·
Posted in Programs, Apps and Websites3 -
3
chrisjojo ·
Posted in Troubleshooting3 -
Rikothegamer ·
Posted in PC Gaming4 -
13
3
1
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
