First PC Assembled - Boots up - No signal on monitor
Solved by Arrogath,
have you flashed the bios up to the 5000 supporting version? You can download it, run the rename executable, put the newly renamed file on an empty USB drive, plug the USB into the BIOS marked port on the back of the machine, and hold the bios flash button for a bit, release and it starts flashing the new version
edit: I forgot to add that if you can it's suggested you flash the bios while plugged into a UPS so that it doesn't get interrupted. The formula board should be okay even if it fails part way with this usb flashback tool though
