Help - need suggestions for getting internet wired
Andrewtchicago
Go to solution Solved by metaleggman,
6 minutes ago, AbydosOne said:
strongly advise against powerline adapters. They rarely get above ~100Mbps.
100Mbps sounds a lot better than 5Mbps.  If they don't have their house wired up for coax (some houses only have one room wired), it could be useful, though what @Jameszy mentioned is pertinent to making sure it works at all.  But if OP has total permission to wire up his 'rents house for ethernet, I wholeheartedly support that option.
31 minutes ago, Andrewtchicago said:
Anyone know who to call in Orange County, CA???
https://www.yelp.com/search?cflt=homenetworkinstall&find_loc=orange+county%2C+CA
Hey all, new here and first post. My parents house is old and big. It doesn’t get wifi across the house and we have a bunch of orbis on a mesh network.
I think we need to wire the house properly because there are no Ethernet cables anywhere other than 1 room with the modem.
im dumb and don’t know anything, and hope that made sense.
Anyone know who to call in Orange County, CA???  Have COX but they can’t help and put for 1,000 MB but get like 5 across the house.
Depending on how old is old, you could use MoCa or powerline adapters.  The former uses your existing cable TV or Internet wiring to form a network, while the latter uses your power wiring.  They don't really get close to true cat 6e+ ethernet installed, but it's sure as hell a lot cheaper, and doesn't require adding new wall receptacles in each room you want wired access.  Assuming your home was built in the 80s or earlier, you should be able to use powerline adapters.
3 minutes ago, metaleggman said:
powerline adapters
4 minutes ago, metaleggman said:
MoCa
If you have existing coax throughout the house (used for cable TV, etc.), MoCA can pretty easily do full gigabit (or quite near to it). Speaking from experience.
Main System (Byarlant): Ryzen 7 5800X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 960 PRO 512GB / 4× Crucial MX500 2TB (RAID-0) | Corsair RM750X | a 10G NIC (pending) | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi (all-around awesome machine)
Proxmox Server (Veda): Ryzen 7 3800XT | AsRock Rack X470D4U | Corsair H80i v2 | 64GB Micron DDR4 ECC 3200MT/s | 4× WD 10TB / 4× Seagate 14TB Exos / 8× WD 12TB (custom external SAS enclosure) / 2× Samsung PM963a 960GB SSD | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case (side panels swapped to show off drives) | VMs: TrueNAS Scale; Ubuntu Server (PiHole/PiVPN/NGINX?); Windows 10 Pro; Ubuntu Server (Apache/MySQL)
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB RAM (SO-DIMM) | Vega 8 Graphics | Lexar 1TB 610 Pro SSD | Dual Realtek 8125 2.5G NICs | VMs: Ubuntu Server (PiHole)
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | Mellanox ConnectX-2 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Camera: Sony ɑ7II w/ Meike Grip | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance 512GB SDXC card
Network:
                           ┌─────────────── Office/Rack ─────────────────────────────────────────────────────────────────────┐
Google Fiber Webpass ────── UniFi Security Gateway ─── UniFi Switch 8-60W ─┬─ UniFi Flex XG ═╦═ Veda (Intel X550.1)
(500Mbps↑/500Mbps↓)                             UniFi CloudKey Gen2 (PoE) ─┴─ Veda (IPMI)    ╠═ Veda-NAS (Intel X550.2)
╔════════════════════════════════════════════════════════════════════════════════════════════╩═ Narrative (Asus USB 2½G NIC)
║ ┌── Closet ───┐    ┌─────────────── Bedroom ─────────────────────────────────────────────┐
╚═ UniFi Flex XG ═╦╤═ UniFi Flex XG ═╦═ Byarlant
   (PoE)          ║│                 ╠═ Narrative (Cable Matters 2½G NIC w/ USB-PD)
   Kitchen Jack ══╝│                 ╚═ Jesta Cannon*
   (Testing)       │        ┌──────── Media Center ────────────────────────────────────────┐
                   └──────── UniFi Switch 8 ─────────┬─ UniFi Access Point nanoHD (PoE)
Notes:                                               ├─ Sony Playstation 4
─── is Gigabit / ═══ is Multi-Gigabit                ├─ Pioneer VSX-S520
* = cable passed to Bedroom from Media Center        ├─ Sony XR65A80K (Google TV)
** = cable passed from Media Center to Bedroom       └─ Work Laptop** (Startech USB-PD Dock)
-> Moved to Networking
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
