Search In
  • More options...
Find results that contain...
Find results in...
Alternative options to TCL 55” Class 6-Series 4K UHD Mini-LED QLED? Please help me tech community!
I am trying to help a friend locate a specific TV: TCL 55” Class 6-Series 4K UHD Mini-LED QLED
https://www.bestbuy.com/site/tcl-55-class-6-series-4k-uhd-mini-led-qled-dolby-vision-hdr-roku-smart-tv-55r635/6424672.p?skuId=6424672
The issue lies in the fact that it is out of stock at a lot of places and he is not able to have it shipped to his house (lives in a bad neighborhood) so trying to find a site to store option.
Does anyone know either where we could find this specific TV in stock or be able to provide similar options in the same price range. Considered the 5-series of the same TV but you end up sacrificing some of the performance gains with local dimming and refresh rate with newer consoles.
Any suggestions with links to items would be much appreciated!
If u havnt already, check out rtings reviews, see if anything catches ur fancy.
https://www.rtings.com/
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w | VDU: Panasonic 42" Plasma |
GPU: Gigabyte 1080ti Gaming OC w/OC & Barrow Block | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + Samsung 850 Evo 256GB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P |
I did dabble around on that website and got some help. I am just not very savvy when it comes to TVs so thought I would put it out into the community. Thank you @SolarNova
Here is a list using their table tool of all the reviewed 120hz FALD equipped TVs.
https://www.rtings.com/tv/tools/table/48447
note not all of them can do 4k 120hz, and not all have VRR.
