How fo i know if usb gen 3.2 gen 2 is used to power transmission?
G-spot
Guys i need help
What do you mean? All devices plugged into USB port will need power to function.
Idk on the be quite website they tell me what power supply i should go whit, and they ask me if usb gen 3.2 gen 2 is used for power transmission, and if i say no, they advice me a 650 watt whit a 76%load, and if i put yes, they raccomand me a 750 watt power suppky
Ah, I believe that website is asking if you will be powering another device with USB PD, which can deliver up to 100W. If you dont plan on powering a compatible laptop through USB, you dont need to worry about that.
-> Moved to Power Supplies
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
