Help me Push my CPU to the limit (currently trying to overclock it) [Ryzen 3 1200]
Solved by Mister Woof,
7 minutes ago, podkall said:Welp, I guess the transistors can't increase their speed forever. Temps were low, no currents nothing went overboard, not even by single digits.
Cores weren't even drawing full 1.325V if the sensors show the actual values.
But I mean, if I could finnish bench at 4,1Gzhz than playing some games that need powerful CPU on 4Ghz shouldn't hurt the CPU right?
Like running stock speed, but OCing if I for example wanna play Warzone.
If it works it works - there's different degrees of stability and everyone has their own perspective on that.
For me an hour of ASUS Realbench and no crashes in the stuff I do is enough, for others its 24 hour P95 stress test.
