WiFi Connection issue.
Solved by Digideath,
My monies on the wifi card. It's a tplink archer series. They all work for a while then suddenly start to develop problems. Dropping connections, no internet, slow speeds.
I have an archer series wifi dongle. It worked for about a year. Now it constantly drops connection and I get the no internet sign at times. It's a nightmare.
I'm using the wifi built in to my motherboard now. It works perfectly well. I tried to keep the dongle for building PCs but it's not even any use for that. Once they're away they're away.
If you swapped out your wifi card with another one, I bet everything would suddenly start working.
