(Please Help) I have a specific case need
Langy
I am looking for a case that has more than 4 3.5inch mechanical hard drive bays, room for a 240mm radiator (+fans) and support a full size mobo.
I don't need anything fancy with RGB and glass etc, just a completely no frills, water cooling high mechanical drive capacity case at low cost.
3..2.....1...... Hit me.
You seem to want a lot for a small price, which isn't easy. Depending on how you define "low cost", this might be a bit much, but the Fractal Define 7 would be an option. You can fit even a 360mm rad into it and way more than 4 3,5inch drives. There is even an XL version of it with even more drive bays.
Gaming Rig: Ryzen 9 5950x | 2x16GB DDR4 3200MHz | XFX Reference 6800 XT | MSI Unify X570 | Corsair MP600 2TB, Samsung 850 Evo 500GB | bequiet 850W Straight Power 11
Server: Ryzen 5 3600 | 4x32GB DDR4 ECC 2400MHz | Asrock Rack X470D4U | Samsung EVO Plus 250GB, 6x Seagate Exos 8TB, Samsung 850 Pro 1TB | bequiet 550W Straight Power 11
You can use PCPartPicker and set filters to auto-sort out the incompatible cases. Make sure to add the 240mm radsiator to your partslist, as it will take that into account and filter out cases like the $38 Zondda cases
https://pcpartpicker.com/products/case/#f=2&J=4,20&sort=price&page=1
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
For the hard drives you might could find a separate drive cage for them and mount it somehow inside or out of a case that fits all your other requirements.
Found this one with only a little trouble
https://www.amazon.com/Sans-Digital-HDDRACK5-5-Bay-Organizing/dp/B001LF40KE/ref=sr_1_1?dchild=1&keywords=hard+drive+cage&qid=1613261711&sr=8-1
