RTX 3080 GDDR6X temp concerns
On 4/12/2021 at 2:37 AM, Stahlmann said:I did take my card apart and reassembled it one more time. But in my stupidity i forgot to make more pictures of the thermal pads. They were contacting the memory, but there was no real "dent" in the pads, so there was no real pressure. That at least explains why my VRAM was "just" hot and not overheating to the point of throttling. Reassembling my card didn't fix this issue. VRAM temps still sit at 95-100°C when playing demanding games at 4K.
They did ask for more pictures of my problem. But i haven't had time to pull apart my loop/GPU again since then. So the conversation with alphacool didn't really come to any conclusion yet. As i don't play any demanding game atm it's not really a priority for me at the time.
Did you contact them about this?
No, I never contacted them but noticed high memory temps. Initially I thought it was just the wrong backplate thermal pads (mine was initial batch where they sent all 2mm thermal pads, they've now updated it to send 3mm pads for 3080 on backplate vram area and 2mm for 3090) but was still having memory temps of 94-98c in nice hash.
Today I took the block apart and noted the thermal pads on the vram (on gpu chip side) were making contact but not a very strong impression. I replaced the stock 1mm pads with 1.5, did a test fit and noticed the thermal paste wasn't spreading too well so was worried the chip wasn't making contact with the coldplate. I just pressed down really firmly on the pads to thin them out a bit and then cranked the screws very tight (tighter than I should have probably). Noticed a very slight bow in the pcb with this but after getting my loop put all together, my gpu core temp is now 3-4c higher (likely the memory heat sinking into the coldplate properly) but memory temps are 30-35c cooler!
IMO this needs like 1.2-1.3mm thermal pads but no one makes those but the 1mm is clearly not enough.
