Cooling Fan/Heatsink, Does it fit?
Solved by lgcas,
2 minutes ago, DannyBoii said:How do I determine that before a purchase?
Look at the height of your ram and the width of the cooler (and the fan height if you can move it, but afaik the 212 is a set position). I'l normally check these and maybe read some reviews; however, the 212 is a pretty thin cooler so you should be fine. For example:
