Thermaltake Toughpower GF1 850W vs PF1 850W ARGB vs Seasonic Focus Plus Gold 750W
By
RmP
in Power Supplies
in Power Supplies
Solved by MrBrightSyde,
2 hours ago, RmP said:Thanks, GF1 or PF1 ARGB, which one is better?
I have a GF1 myself and it has been very quiet, so I can recommend it noise-wise. Either one would work in terms of quality, but if you don't care about the ARGB, I would get which ever is cheaper
2
3
drowninginmetal ·
Posted in New Builds and Planning1 -
1
2
VoiceLessQ ·
Posted in General Discussion4 -
1
2
CarlBar ·
Posted in Troubleshooting5
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
