Low Fps in GTA V
Marto12345
I get 25-40 fps in gta online.
GPU usage 20%-65%.
CPU usage 45%-50%.
My Specs:
Ryzen 5 2400g
16GB ram-2x8 2666mhz
RX 580 8GB strix.
1680x1050 resolution.
That's normal, Online runs like shit.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
Are you running it from a HDD or SSD? Having it on an SSD could help considerably considering how much the game needs to load in new assets.
I get about the same fps, but I have worse hardware, Athlon x4 860k OCd to 3.9ghz, Zotac gtx 970 reference, and I'm running the game from the HDD my laptop had before I upgraded it to a SSD
GPU usage 20%-65%.
CPU usage 45%-50%.
My Specs:
Ryzen 5 2400g
RX 580 8GB strix.
What settings are you running it at? For me I turned up the resolution scaling to 2x, so my graphics card would get used more, as I'm being bottlenecked by the cpu
Make sure to stay away from the scalers under Advanced graphics options. They tank the FPS a lot. Also, grass quality eats up a lot aswell on the highest settings.
PC Setup:
HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel
Intel Core i7-10700K + Corsair Hydro Series H100x
G.SKILL TridentZ RGB 32GB (F4-3600C16Q-32GTZR)
ASUS ROG STRIX RTX 3080Ti OC LC
ASUS ROG STRIX Z490-G GAMING (Wi-Fi)
Samsung EVO Plus 1TB
Crucial MX500 2TB
Crucial MX300 1.TB
Corsair HX1200i
Peripherals:
Samsung Odyssey Neo G9 G95NC 57"
Samsung Odyssey Neo G7 32"
ASUS ROG Harpe Ace Aim Lab Edition Wireless
ASUS ROG Claymore II Wireless
ASUS ROG Sheath BLK LTD'
Corsair SP2500
Beyerdynamic TYGR 300R + FiiO K7 DAC/AMP
RØDE VideoMic II + Elgato WAVE Mic Arm
Racing SIM Setup:
Sim-Lab GT1 EVO Sim Racing Cockpit + Sim-Lab GT1 EVO Single Screen holder
Svive Racing D1 Seat
Samsung Odyssey G9 49"
Simagic Alpha Mini
Simagic GT4 (Dual Clutch)
CSL Elite Pedals V2
Logitech K400 Plus
While GTA Online does tend to run worse in general than story mode there are a few settings to check that may help.  First, make sure MSAA is turned off completely. The implementation of MSAA is really poorly optimized in GTA V and it usually hits your FPS pretty hard even on higher end systems.  If you want to get rid of aliasing I would turn on FXAA and, if your PC has the horsepower to handle it, try turning going to the advanced graphics settings and try setting the frame scaling mode to x1.2 or so.  The frame scaler will still be a performance hit but should be less so than MSAA in my experience.  Second, if you have any settings turned on under the advanced graphics section try turning them down. These also tend to hit performance pretty hard.  Lastly, try turning down your reflection quality and making sure reflection MSAA is off. That affects performance quite a bit as well.  Hope that helps.
Tried running it on my ssd,same performance.
Very high and even on low i'am getting the same fps...
Grass is on low,didn't cnange anything in advanced settings.
Tried,but didn't have any change 😞
  • 1 month later...
GPU usage 20%-65%.
CPU usage 45%-50%.
My Specs:
Ryzen 5 2400g
RX 580 8GB strix.
Gta v is very poorly optimised for ryzen CPUs. There is no real way to fix this issue.
I have a Ryzen 5 3600 and Rtx 3060ti and only get 40 to 50 fps on 1080p(Only online though) In story mode i get like 150 fps average on the in game benchmark.
Well have all of your driver updatd, o also the app to control the Gpu updated?  i would like to ask you i have a similar configuration : Ryzen 5 3600, 16GB Ram 2666mhz, XFX RX590 8GB. Acording to my radeon software i've got 150fps during the game (online), but i would like to ask you, and also someone else, is only at me but when i'm playing online, gta is using 10/11 GB of ram?
