switched motherboard from tuf z270 to b550 msi carbon wifi but no display works
Solved by WhitetailAni,
Your motherboard will likely need a BIOS update, and using 2133 MHz RAM really holds back Ryzen's performance.
Your GTX 980 is most likely fine.
EDIT:
I would advise getting some 3600 CL16 RAM.
asususr ·
Posted in General Discussion0 -
specsdude99 ·
Posted in CPUs, Motherboards, and Memory2 -
1
2
6
1
Tydn12 ·
Posted in New Builds and Planning4 -
2
ID0 ·
Posted in Networking2 -
eviohh ·
Posted in Troubleshooting3
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
