I need help finding the name of a cable to power this thing (Image included)
Solved by DankDoodles,
21 minutes ago, Senzelian said:It'd be much cheaper to get an 8-pin and a 4-pin EPS extension.
Keep in mind that the 4-pin EPS isn't even needed if you're not overclocking.
For example:
I have plugs that plugin into the power supply with 8-pin, and then it splits into two 4-pin connectors.
Would that still work for that cable extension you mentioned?
