GTA IV picture quality issue
Solved by Almercenary,
1.0.4.0 isn't the best patch in terms of stableness. ICEnhancer is ported to EFLC patch so you could try that, just back it up. Could also be your newish GPU that it can't handle. With my 7970 I had to use " -norestrictions -nomemrestrict" ( in launch options)to actually get it to work.
damian61 ·
Posted in Troubleshooting0 -
kofman13 ·
Posted in Linux, macOS and Everything Not-Windows1 -
Gabefair ·
Posted in General Discussion1 -
Jeeperforlife ·
Posted in New Builds and Planning5 -
darkwolfotf ·
Posted in Audio0 -
6
5
play_circle_filled
Latest From ShortCircuit:
If you can only get one computer, get this one. - ASUS ROG G14 (2024)
