Custom case for iMac 27 inch 2015
madsmed
I need help to build custom case for iMac 27 inch late 2015 A1419.
The LCD display broken, and I don't want to spend money to buy it's display, instead of using cheaper external display.
Another case is..
There is 2 and half of 4 led indicator. I believe.. First led for power supply, second is for the mainboard, third for GPU, and fourth for display. Third LED not fully bright. Fan spinning faster since starup but somehow, the external monitor working good..
So.. I just thinking to bring all the machine out of the iMac steel. And put into a custom case.
Or if you having any solution and advice please, I love to know it..
Thanks..
Edited by madsmed
Added more info..
The lcd or only the front glass?
If you want cheap lcd, try getting it used.
Otherwise just use the original body and just put the new monitor in front of it.
What iMac are you talking about? Is it a 2009-2011 model or a 2012-current model?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
-> Moved to Cases and Mods
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
He said it's an A1419 2015 model...
elephants
Not when I commented, otherwise I wouldn't have asked.
Main System: Phobos
