LG CX OLED auto dim help
e22big
My friend just buy LG CX48 OLED not too long ago and he doesn't like it one bit. One issue with this OLED that I discovered later on is that it has a basically terrible brightness in SDR mode (250 nid and less) and just decent in HDR, which make it horrible as a PC gaming monitor but worst part is the TV keep dimming itself no matter what setting which make the image quality suffered even more.
I am trying to find a way to improve his experince, brightness can be fixed somewhat by just using a TV mode, but auto dimming is a massive pain and I can't find anyway to fix it until now, do you have any good advice I could try?
that what happens when big channels like LTT covers  a niche product and ignore its problems
when I commented on their video about this they ignored it
I was excited to buy this TV but the ABL issue (its what you're talking about) is what made change my mind and wait for an oled or newer tech monitor
can your friend return the TV ?
  Is he in a rather bright room? He can try turning up "OLED Light" and "Peak Brightness" settings if he hasn't done so already.
That's the ABL (Auto Brightness Limiter) feature (changing the Peak Brightness setting will change its behaviour as well). Technically it can be disabled through a service menu, but it's there for a reason. Not sure how bad it is on a CX, but on my C9 it's hardly ever noticable.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
I initially had a similar problem with the B9 when I got it. There is a menu setting that disables it but I can't remember what it was called. It might have been the eco mode thing.
Main system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, Corsair Vengeance Pro 3200 3x 16GB 2R, RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
yeah, and to be fair, even without ABL, SDR brigtness in this monitor is barely usable - and as a monitor and not TV, SDR is absolutely important as you can't just use HDR in Windows all the time
to be fair, I did see that it was quite bad in rting but didn't really see that it is 250 nit bad
I haven't go to see it at his place either but he said it's bad - like the monitor just dim to the minimum whenever he used flashy attack pattern in Monster Hunter
Just had a quick look through the menu on mine, it might be Energy Saver. Instead of Auto it is on Medium. I don't notice brightness changes in actual use, but if left idle with a static image for some time it dims slightly and returns once there is activity.
cool I'll let him know and may be trying it out myself
If brightness is an issue, ensure u dont have BFI enabled. you'll loose some moving picture clarity, but gain normal brightness back.
250nits 'should' be enough, unless ur in a bright room, in which case OLED probably wasnt the best choice.
OLED is still developing in the brightness department, upcoming OLEDs should have a 20% boost for basic models, a new upcoming Sony top end model has been measured at 1300nits.
Disabled ASBL* in the service menu. You'll need a IR blaster equipped device to use the Service App or a Service remote (u can buy from amazon/ebay)
ASBL is what will be kicking in when using the Display for browsing and text documents.
ABL** can NOT be disabled but you can reduce its effectiveness by running with OLED light at ~60%, however since ur complaining about brightness this probably isnt an option.
*Automatic Static brightness Limiter
** Automatic brightness Limiter
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
  • 4 months later...
I'm sorry to perhaps resurrect an old thread, but is there a way to have ABL e.g. kick in after say 3-5 seconds of all white image instead of instantly?
I'm playing Soul Calibur 6 and whenever there's a KO, the screen briefly flashes (as it's supposed to), but it turns gray whenever it happens.
not sure if you could do that, as it turn out, ABL adjustment on CX OLED wasn't obvious at all, even trying to leave it off wasn't that easy - guess you will have to experiment and see if any works
  • 2 months later...
Happy owner of an LG OLED B8 converted to C9 over here. Using it as my main gaming pc monitor.
Here's what you need to do to prevent the screen auto dimming.
First, deactivate HDR in Windows when not playing an HDR game.
Second, set your OLED Light level at 29 or under. (you can test higher but over a certain level your screen will dim even tho you made those changes. )
Third, if you have a smartphone with an IR blaster install AnyMote Smart Remote if not then search for this on Amazon MKJ39170828.
Finally, press the "In-Start" button on the remote and enter the password (0413), then go into the OLED submenu and turn "TPC Enable" to off and "GSR Enable" to off. Press the "In-Start" button to close the service menu.
Hope it helps.
Hope it helps.
Thanks, appreciate that. Will try that all when the 42" OLED are released in early 2022.
DAC/AMPs:
Klipsch Heritage Headphone Amplifier
Headphones: Klipsch Heritage HP-3 Walnut, Meze 109 Pro, Beyerdynamic Amiron Home, Amiron Wireless Copper, Tygr 300R, DT880 600ohm Manufaktur, T90, Fidelio X2HR
CPU: Intel 4770, GPU: Asus RTX3080 TUF Gaming OC, Mobo: MSI Z87-G45, RAM: DDR3 16GB G.Skill, PC Case: Fractal Design R4 Black non-iglass, Monitor: BenQ GW2280
  • 11 months later...
came across this and wanted to share the fix i found. I have the LG 48GQ900-B and couldn't find a simple setting for turning off the auto-dimming whenever there were still images/screens (I'm a software engineer and I didn't purchase this for gaming) when web browsing or reading any documentation. It was quite frustrating. I ended up messing around with the settings and I found if i kept the brightness at 100 but turned the contract to anything above 60, that's when the auto-dimming occur. My settings are brightness at 100 and contrast at 60 and I no longer have auto-dimming. By auto-dimming, I mean immediate dimming moving from one window to another. Not like an idle screen or after long use.
Hope this helps someone! It's a lovely monitor.
The auto DIM - ABL cannot disable without go to service mode. Once you go to service mode disable, if not wrong they will be mark there and warranty is void.
That the reason until now I don't buy OLED TV from LG use as monitor.
Another issue is constant brightness issue where brightness heavy change when maximum / normal view of the windows explorer or any white bright apps, the new coming Asus PG42UQ can make it constant as they is option but from review, the SDR brightness will became 200 nits only. 😅 After I seen that review, not so interesting as well.
PC: AMD Ryzen 9 5900X, Gigabyte GeForce RTX 4090 OC 24G, X570 AORUS Elite WIFI Motherboard, HyperX FURY 32GB DDR4-3200 RGB RAM, Creative Sound Blaster AE-9 Sound Card, Samsung 970 Evo Plus M.2 SATA 500GB, ADATA XPG SX8200 Pro M.2 SATA 2TB, Asus HyperX Fury RGB SSD 960GB, Seagate Barracuda 7200RPM 3.5 HDD 2TB, Cooler Master MASTERLIQUID ML240R ARGB, Cooler Master MASTERFAN MF120R ARGB, Cooler Master ELV8 Graphics Card Holder ARGB, Asus ROG Strix 1000G PSU, Lian Li LANCOOL II MESH RGB Case, Windows 11 Pro (22H2).
Laptop: Asus Vivobook "A Bathing Ape" - ASUS Vivobook S 15 OLED BAPE Edition: Intel i9-13900H, 16 GB RAM, 15.6" 2.8K 120hz OLED | Apple MacBook Pro 14" 2023: M2 Pro, 16 GB RAM, NVMe 512 GB | Asus VivoBook 15 OLED: Intel® Core™ i3-1125G4, Intel UHD, 8 GB RAM, Micron NVMe 512 GB | Illegear Z5 SKYLAKE: Intel Core i7-6700HQ, Nvidia Geforce GTX 970M, 16 GB RAM, ADATA SU800 M.2 SATA 512GB.
Monitor: Samsung Odyssey OLED G9 49" 5120x1440 240hz QD-OLED HDR, LG OLED Flex 42LX3QPSA 41.5" 3840x2160 bendable 120hz WOLED, AOC 24G2SP 24" 1920x1080 165hz SDR, LG UltraGear Gaming Monitor 34" 34GN850 3440x1440 144hz (160hz OC) NanoIPS HDR, LG Ultrawide Gaming Monitor 34" 34UC79G 2560x1080 144hz IPS SDR, LG 24MK600 24" 1920x1080 75hz Freesync IPS SDR, BenQ EW2440ZH 24" 1920x1080 75hz VA SDR.
Input Device: Asus ROG Azoth Wireless Mechanical KeyboardAsus ROG Chakram X Origin Wireless MouseLogitech G913 Lightspeed Wireless RGB Mechanical Gaming Keyboard, Logitech G502X Wireless Mouse, Logitech G903 Lightspeed HERO Wireless Gaming Mouse, Logitech Pro X, Logitech MX Keys, Logitech MX Master 3, XBOX Wireless Controller Covert Forces Edition, Corsair K70 RAPIDFIRE Mechanical Gaming Keyboard, Corsair Dark Core RGB Pro SE Wireless Gaming Mouse, Logitech MK850 Wireless Keyboard & Mouse Combos.
Entertainment: LG 55" C9 OLED HDR Smart UHD TV with AI ThinQ®, 65" Samsung AU7000 4K UHD Smart TV, SONOS Beam (Gen 2) Dolby Atmos Soundbar, SONOS Sub Mini, SONOS Era 100 x2, SONOS Era 300 Dolby Atmos, Logitech G560 2.1 USB & Bluetooth Speaker, Logitech Z625 2.1 THX Speaker, Edifier M1370BT 2.1 Bluetooth Speaker, LG SK9Y 5.1.2 channel Dolby Atmos, Hi-Res Audio SoundBar, Sony MDR-Z1R, Bang & Olufsen Beoplay EX, Sony WF-1000XM5, Sony WH-1000XM5, Sony WH-1000XM4, Apple AirPods Pro, Samsung Galaxy Buds2, Nvidia Shield TV Pro (2019 edition), Apple TV 4K (2017 & 2021 Edition), Chromecast with Google TV, Sony UBP-X700 UltraHD Blu-ray, Panasonic DMP-UB400 UltraHD Blu-ray.
Mobile & Smart Watch: Apple iPhone 15 Pro Max (Natural Titanium), Apple Watch Series 8 Stainless Steel with Milanese Loop (Graphite).
Others Gadgets: Asus SBW-06D2X-U Blu-ray RW Drive, 70 TB Ext. HDD, j5create JVCU100 USB HD Webcam with 360° rotation, ZTE UONU F620, Maxis Fibre WiFi 6 Router, Fantech MPR800 Soft Cloth RGB Gaming Mousepad, Fantech Headset Headphone Stand AC3001S RGB Lighting Base Tower, Infiniteracer RGB Gaming Chair
200 nits SDR full screen is pretty good though, even on LCD, I typically set my screen to 200 nits (mostly to save energy) and it's a bit dim but not bad at all
Ya, should be OK but I think if can reach at least 250 nits is better.
I set 80 % for one of my monitor which is 250 nits, in this case which is exact 200 nits, but in case need extra brightness then it is reaching the limit. 😅
