Search In
  • More options...
Find results that contain...
Find results in...
Second Monitor For Viewing Stuff
Go to solution Solved by AnirbanG007,
7 minutes ago, Kerbalino said:
Hello everybody!
I am looking for a second monitor which I can use to look stuff up while e.g. playing games on my main monitor.
My current main monitor is an AOC24GU 24'' with a TN panel, 1080p resolution and a 144Hz refresh rate. I am fine with the second monitor being 60Hz and having a TN panel, although it should be 1080p and preferably 24''. I am also going to have it stand vertically, because I don't have enough space on my desk.
My budget is around 100€. I could probably push it to 150€ if I give it a little bit more time. Any recommendations are welcome!
Mark
For 16:9, i'd go with this monitor: BenQ GW2480 24-inch
But, my personal choice would be this one: Dell 24 inch U2415. Although the price of this one could be more than your budget in your country. Also this is 16:10.
Hello everybody!
Mark
CPU: Ryzen 5 3600Motherboard: MSI B450 Tomahawk Max GPU: ASUS Strix RX5600XT O6G ═ RAM: HyperX Fury 2x8GB 2666MHz CL16 ═ PSU: be quiet! Pure Power 11 500W ═ Cooler: be quiet! Pure Rock 2 ═ SSD: Samsung 970 Evo Plus 250GB M.2 SSD ═ HDD: Seagate Barracuda 2TB ═ Case: Lian Li Lancool II Mesh RGB
2 minutes ago, Kerbalino said:
Hello everybody!
Mark
what country?
geometry is hard
b550 > x570
You do not want a TN monitor when you'll use it vertically.
Current Specs:
CPU: AMD Ryzen 5 5600X - Motherboard: ASUS ROG Strix B550-E - GPU: PNY RTX 3080 XLR8 Epic-X - RAM: 4x8GB (32GB) G.Skill TridentZ RGB 3600MHz CL16 - PSU: Corsair RMx (2018) 850W - Storage: 500 GB Corsair MP600 (Boot) + 2 TB Sabrent Rocket Q (Storage) - Cooling: EK, HW Labs & Alphacool custom loop - Case: Lian-Li PC O11 Dynamic - Fans: 6x Noctua NF-A12x25 - AMP/DAC: FiiO K5 Pro - OS: Windows 11 preview - Monitor: ASUS ROG Swift PG35VQ - Mouse: Logitech G Pro + Powerplay - Keyboard: Logitech G915 TKL - Headphones: Beyerdynamic Amiron Home - Microphone: Antlion ModMic
Temperatures @steady state: Furmark + CinebenchR23 running for 1 hour. Fans @850RPM. Pump @1600RPM.
Water: 37°C
CPU: 73°C
GPU: 54°C
2 minutes ago, Downkey said:
what country?
Austria.
Why is that? Is it because of colours or view angles or something else?
Hello everybody!
Mark
Attention is what makes life meaningful.
Also, please quote me for a reply. 🙂
The UltraSharp is sadly much more expensive over here. However, the BenQ one looks pretty good and fits nicely into the budget! I will put it on my list of conciderations hehe. Thanks for recommending!
The viewing angles of a TN display are very noticeable when you use one vertically. There will be a significant difference in the image horizontally when the monitor is vertical.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
Thanks for clarrifying! IPS panels with this size and refresh rate generally seem cheap in my country, so I might go for one at the end.
