Turn up the heat - Rocket-Lake-S CPUs charted and benchmarked
williamcll
Oddly, the 11900K seems to be a faster version of the 11700K rather than having extra cores and cache.
Quote
According to the chart, Intel 11th Gen Core-K series will feature Core i9-11900K, Core i7-11700K, and Core i5-11600K. Only the latter is a 6-core CPU, while both Core i7 and Core i9 will debut with 8-cores.The K-series are feature 125W TDP and DDR4-3200 memory support. While there is no change in TDP compared to the Comet Lake-S series, the memory support has improved. MSI slide confirms that the Core i9-11900K will boost up to 5.3 GHz in Thermal Velocity Boost mode with all cores reaching up to 4.8 GHz. The base clock is as rumored before, 3.5 GHz.The 11700K will be 300 MHz slower, as it does not support Thermal Velocity Boost.  This SKU will have a 3.6 GHz base clock, which is 100 MHz higher than i9. The list ends at Core i5-11600K which is a 6-core and 12-thread CPU with a base clock of 3.9 GHz and turbo reaching 4.9 GHz.
Intel-11th-Gen-Core-Rocket-Lake-Specific
Over in Chiphell, a user was able to get hold of a 11900KF and ran a stress test with a basic 360mm Cooler
Note all core clock being 4.78Ghz and does not thermal throttle at 98C. CPU voltage was 1.325V as opposed to the image shown. The power consumed was 250W.
Source: https://videocardz.com/newz/intel-core-i9-11900kf-heats-up-to-98c-with-360mm-aio-cooler
https://www.chiphell.com/thread-2297915-1-1.html
Thoughts: I guess this was the real reason that Intel was designing that thermal-electric cooler for. I do wonder how much the IPC has gone up in comparison to the 10700K however. Maybe it's time for people to make more 420mm AIOs?
Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB
            CPU: Ryzen 9 5900X          Case: Antec P8     PSU: Corsair RM850x                        Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM
            Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition
So peak power is similar ball park to 10th gen. Intel claimed up to 19% IPC uplift with Rocket Lake. This contrasts with an average 18% claimed for Sunny Cove/Ice Lake, which is the architecture it heavily draws from. It will vary depending on software so we'll have to await independent testing once they are officially available.
Main system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, Corsair Vengeance Pro 3200 3x 16GB 2R, RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Rocket Lake is such a weird release. In a vacuum it would be a decent release with the IPC increase, but with Alder Lake is rumored to be coming in September I just don't see who's in the market for one of these. I guess if you don't have a PC sure but for literally anyone else you'd be better served waiting as you're looking at an even bigger performance increase plus DDR5, it's just going to a way longer lasting platform.
Dell S2721DGF - RTX 3070 XC3 - i5 12600K
A big part of the generational increase in performance is the rise of clock speeds.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
Alder Lake has only been stated as 2H this year by Intel. While in theory that could be as early as July, usually it'll be right at the back end of the window. If it was really September, they would likely have said Q3 instead. September would be a good time, it means product is ready in time for the holiday season, but I'd assume later, even without the risk of further delays.
Also people tend to buy for current needs. If you need a new system within the Rocket Lake time window however short it may be, it will be a consideration. We'll have to wait and see what Intel's availability and pricing will be like, but from the sounds of things supply of desktop Zen 3 isn't going to be great as they prioritise other more profitable areas.
In the past that may have been a trend, but if the table in OP is correct, there is no uplift to the boost clocks on the top part relative to current, and even a slight reduction in base clock. Real world performance change will be driven by IPC.
Admittedly, there are only a handful of cases that can support a 420 rad. Popular cases like the O11D (all versions), Meshify C, P400A, 500DX, Lancool 2 Mesh, 4000D and 5000D, etc are all out.
P500A, Meshify 2, Silent Base 802 are three off the top of my head that support a 420rad (obviously there are older cases but I'm thinking the "new" cases). and all of those are "mid" towers that really should be classified as "full towers (being over 70L large) IMO
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
My case doesn't support a 420 rad,even though it's a big case that supports E-ATX boards without any problems.
But it can support two 360 radiators,and a single 120 all at the same time.
You can make a custom loop with two 360 radiators in a lot of the cases you mentioned,and it's performance is superior to a single 420 rad.
Note about my case: I think that i might be able to mount a 420 radiator if i use only 3 fans instead of 4.
420 = 3x140mm fans. You're thinking of 480mm (4x120mm)
Yes, two 360 rads are possible in many cases, but that requires a custom loop. We're specifically referring to AIO's for the more casual PC builder
Think my Fractal Design R6 supports it in the top.
My Rigs | CPU: Ryzen 9 5900X | Motherboard: ASRock X570 Taichi | CPU Cooler: NZXT Kraken X62 | GPU: AMD Radeon Powercolor 7800XT Hellhound | RAM: 32GB of G.Skill Trident Z Neo @3600MHz | PSU: EVGA SuperNova 750W G+ | Case: Fractal Design Define R6 USB-C TG | SSDs: WD BLACK SN850X 2TB, Samsung 970 EVO 1TB, Samsung 860 EVO 1TB | SSHD: Seagate FireCuda 2TB (Backup) | HDD: Seagate IronWolf 4TB (Backup of Other PCs) | Capture Card: AVerMedia Live Gamer HD 2 | Monitors: AOC G2590PX & Acer XV272U Pbmiiprzx | UPS: APC BR1500GI Back-UPS Pro | Keyboard: Razer BlackWidow Chroma V2 | Mouse: Razer Naga Pro | OS: Windows 10 Pro 64bit
First System: Dell Dimension E521 with AMD Athlon 64 X2 3800+, 3GB DDR2 RAM
PSU Tier List          AMD Motherboard Tier List          SSD Tier List
not sure about it having ddr5 though
The all-core TVB for the 10900K is 4.9GHz so the all-core clocks are actually very slightly lower.
Inb4 most games will tank in performance due to them using the low performance cores and not understanding how to operate a hybrid CPU with no upcoming updates to do so.
I think alder lake is weird, it's like phone CPUs no? One core at 5.5GHz max boost, another core at 2.3GHz max boost. How will older games know which core to use, or will they even function anymore? Yes, i know i can allocate cores. I shouldn't have to though. An upgrade just for the CPU is already over 1000€ ( CPU price, good motherboard, good RAM, good PSU to support everything)
It does, 420rad support was as early as the R5/ Define S, but again, was only focusing on "new" cases
I can mount 3x 480 RADs in my LD PC-V8, 63mm deep EK XTX ones too. It is a bit tight in the bottom bay with two of them but you can 😀
Not that I need that much RAD but it does mean I can run totally passive so that's a bonus. At least I know I'm ready for basically anything, some would say too ready.
Assuming Intel works closely with Microsoft the Windows scheduler should take care of this. But we see how long it took them to get scheduling working properly with Ryzen, so yea.
Makes you wonder how much in advance the CPU manufacturers work with MS (and other OS areas like Linux) to get CPU support before launch. I don't mean just working at all, but working well.
While it remains to be seen what benefit the hybrid tech can bring to desktop, there is a workaround for anyone considering Alder Lake: get the models without the slow cores.
IF the rumours are true about the 11900K going up to 98C with a 360 RAD then I really don't see the point of it especially if the 11700K is cooler and is so close to it in performance.
The last time someone tried a hybrid architecture (AMD with Bulldozer) it didn't work out too well. Though its Intel and they are well known in the industry so it might be different than Bulldozer.
Bulldozer is nothing like this. Each core looked the same to the OS/software.
Alder Lake will have two different types of core offered. The nearest we have on x86 is Intel Lakefield. This is new ground for x86, even if it has been in mobile space for many years.
They are the same CPU just one is slightly higher binned. These temps are in a worse case scenario though, you are unlikely to get close to these temps in a gaming workload.
Bulldozer wasn't a hybrid arch at all, at least not in the big little sense.
Technically Bulldozer was an abomination:
You can't call what Bulldozer had cores,yet it operates like it has cores.
That's why experts called it a 4 modules/8 threads CPU,and not 8 cores/8 threads.
People use PC for more than games FYI. Regardless, Windows scheduler will handle it I think. This isn't Intel's first x86 hybrid design, Lakefield was a test run essentially.
It's not weird, we've seen hybrid architectures used in smartphones for ages. If anything it's weird that we didn't see it sooner on x86, laptops will benefit a lot from this. No doubt it'll be less useful for desktops, but it'll still offer better power efficiency when idle or doing lower power tasks like web browsing. Also assuming all the cores can be used simultaneously I could also see it being beneficial for non-gaming multithreaded workloads.
Yeah.. if you buy all high end parts and don't already have a PSU. You can easily upgrade your CPU while spending half of that or less.
hopefully microsoft improves windows thread optimization or else people would just have to disable the weak cores or take a performance penalty. in a lot of games you can get a big performance boost by disabling hyperthreading
maybe require something like process lasso in the mean time
