do all case fan are gonna work in a fan hub as long as it has 3/4 pin?
ninjaboyxd629
im about to buy this case fan and Capture.PNG.fa29e2d696ccb5f55822c08b22c16c88.PNGyou can see the 3 pin there the seller said it wont work i said why but he didnt reply yet
can you tell me if all fans will work on a fan hub as long as it has 3/4 pin? if itsnt gonna work pls tell me why i know that theres a molex there but my psu only have 2 molex and im gonna buy 6 fans for my case so only 2 will work my mobo have 2 fan header but its the same as fan hub right? because fan hub is just a fan header but you can connect many fans
You can use whichever one of the connectors you want. The molex is just optional if you don't have a free fan header.
Now the real question is who decided to make a fan out of cheap $2 chinese vending machine jewelry
You can't use powered splitter (those with SATA power) since the fan isn't PWM. But using 3-way or Y.splitter is fine.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
