7 fans, only have 6 RGB Fan slots available, what to do?
Solved by IkeaGnome,
53 minutes ago, DankDoodles said:I am guessing it isn't a good idea to use a Asus AIO with corsair fans?
I did that with my old RGBtastic set up. I pulled this picture from the Corsair forums. You'd be looking at wiring very similar to this. Just replace the LED strip off the PRO for one of your fans if you want all 7 to be lit up.
Corsair iCue RGB has a learning curve. Once you learn how to use it, I prefer it actually. It's very simple to expand and subtract RGB from. It also has support to control some ASUS hardware. My old ROG Mobo and ROG 2070 could be controlled in iCue.
