Can you fix a blown power supply?
Solved by Electronics Wizardy,
Just now, jordanjmdurno said:There was a power surge when the power came back on, the power had cut briefly. After that my pc won't turn on. I do so hope it's only the PSU hehe...
You can normally fix it, but if you haven't done anything similar I wouldn't advise taking it apart. Its probably cheaper to get a new one than paying someone else to fix it.
superbrett2000 ·
BallinBonobo ·
Posted in Troubleshooting0 -
runningdecoy ·
2
joshp305 ·
Posted in New Builds and Planning1 -
3
4
Inception9269 ·
Posted in PC Gaming0
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
