My monitor is blank..
Solved by Digideath,
Well its def not the monitor then. It's a problem with the pc itself. Somethings not right with it and it doesnt like it.
Make sure the cpu power connector, the 24 pin connector and the gfx card power connector are def in place properly. Also re seat the gfx card. Make sure the fans on it are def coming on.
Also clear the cmos. Remove the battery for a while. Reset the bios
And if none of that works the next step is to try and rule out gpu and ram.
The gpu is awkward. You need another gpu or access to another system to run tests.
The ram is simple. Pull out the ram. Put one stick in slot a2 and try it out.
