Rtx 2060 over heating issue
Solved by Yuvan Reddy,
Change thermal paste on gpu die if you are comfortable. This will mostly solve the issue.
Or else, just blow air on gpu which will remove dust and cool your card better
SyndiShanX ·
Posted in Audio0 -
Nexxus ·
Posted in Programs, Apps and Websites2 -
ds5018 ·
Posted in Troubleshooting0 -
3
Muzzy2002 ·
Posted in New Builds and Planning4 -
modern_officer ·
Posted in Laptops and Pre-Built Systems5 -
3
Coding2bLazy ·
Posted in Troubleshooting8 -
Thezgamer75 ·
Posted in Troubleshooting1 -
6
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
