Zen3 PBO Questions
Solved by AndreiArgeanu,
Precision Boost Overdrive is limited by the boost clock listed on AMD's website and is mentioned by themselves as one of the limiting factors. PBO will not push past the boost clock listed on AMD's website which in this case happens to be 4.6ghz.
https://www.amd.com/en/support/kb/faq/cpu-pb2
Edit: Gamer's Nexus also explains this in a video/article
https://www.gamersnexus.net/guides/3491-explaining-precision-boost-overdrive-benchmarks-auto-oc
