Question About USB Hub
Pavendaxx
Go to solution Solved by BlueChinchillaEatingDorito,
12 minutes ago, Pavendaxx said:
Does connecting mouse, keyboard, headphone, and drawing tablet into one usb hub 3.0 will work? I want to make my setup cleaner by connecting all the peripheral under the table into one usb hub. And also what if I connect three usb at the same time to the usb hub, does the pc will still read all three of them? I literally dont know how usb hub work.
Yep, it'll work. You may need to find one that's powered though. I find those to be the most stable.
yes those will all work just fine connected to a hub, you shouldnt have any issues
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.2.1) | iPhone XR (iOS 17.2.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
Should be no problem since all device you listed don't need very much bandwith.
You might notice a difference in input lag if you are a hardcore gamer thou.
like said above, if you want a lot plugged in, you would look into a powered hub. Else you also need to connect to the system for the data too, don't think there much hubs like that with bluetooth/wireless connections? Could be a thing in the future, maybe that will look slick.
