MSI Duke RTX 2080 Fans spin at max speed, ignoring custom fan curve
Hi, I'm the dude from that video and I did solve this problem!
All I had to do is apply fresh thermal paste on the GPU. Didn't think it would help, since the card isn't that old but it made a world of difference.
Here are some pics so you know what to expect: https://imgur.com/a/VSEfiM7
There's a lot of guides on how to do it so I won't write another one, but let me know if you want some pointers. It's pretty simple if you know how to use a screwdriver Just be gentle, don't lose any of the thermal pads and prepare some alcohol for cleaning (ideally IPA).
As for fan curves I reverted everything back to default and let the card's BIOS do the work. It's not a software issue, that's why Afterburner wouldn't help. I think the thermal paste quality or the way it's applied from factory isn't very good, which creates hotspots on the die and sensors go crazy. If it's anything like CPUs then the highest temperature reading is considered, not average. So as long as you have an even layer of good paste everything should be fine.
