Search In
  • More options...
Find results that contain...
Find results in...
Best >$150 motherboard for fx 8350
Help. I am looking for a motherboard under $150 for my fx 8350. I would like to over clock a little if possible. Thanks.
GA-990FXA-UD3
[Minnesota Rig: AMD 5600X | ASRock X370 Taichi | Patriot 4400MHz 16GB | Crossfire Vapor-X R9 290s | 970 Evo | EVGA 1300W G2 | S340 Elite | Kraken X60 | Win 10]
[Chile Rig: AMD FX-9590 | Asus Crosshair V Formula-Z | G.Skill 16GB 2400MHz | MSI RX 480 | Intel + Samsung SSDs | CM 240mm AiO | EVGA 1000 P2 | Win 10]
[Laptop: HP Elitebook 745 G3 | AMD A12-8800B | Radeon R7 | 16GB DDR3 | Samsung 960 Evo | Intel 7265 | Qualcomm 4G LTE | 1920x1080 14.1"| Win 10]
I'm loving my Asus M5A99FX. $150 on Newegg last time I checked. Might be cheaper other places.
/// POLICE ASSAULT IN PROGRESS ///
the gigabyte A-990FXA-UD3 is pretty much the go to board for the 8350. You wont find a better board for the money
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
any preference to colour scheme? or form factor
got to love Asus components
GA-990FXA-UD3 ver 4.0. if planning on overclocking, use the 4.0 with the better VRM cooling.
^This
Is the one on newegg version 4.0? And the gray and black color is perfect.
Yes the heatsink design and the different color ram slots give it away.
 Share
