AUX cable broke motherboard
23 minutes ago, THE_NORMAL_GUY63 said:here is what happens (dont mind the cables)
Ah that is onboard video, that's a different story then. Many possibilities. The easiest is to get a graphics card to test it out. If it then works, the board is fine, if not the board is either toast or needs fixing. You can take it out of the case and if you have a multimeter and a good magnifying glass, try to locate damaged components or missing ones at that. If all you want is the data off those drives, putting them into a external case is the fastest solution. Also check the motherboard for jumpers. There should be one enabling the graphics card. If the small jumper cap is missing it can cause the issues. You could also have a bad vga connector, which can be solved with some soldering. All in all a very lengthy process.
