24 Pin Connector looks like its not plugged in. (fixed)
Solved by minibois,
This latch has to catch on this hook:
So yes, the cable is not connected properly at the moment.
Push in the cable on both sides, maybe with some on the other side of the motherboard - like a piece of cardboard - so you can apply force without bending the motherboard.
OldFord76 ·
Posted in Troubleshooting0 -
Blawe17 ·
Posted in Troubleshooting1 -
Ronbaow ·
zoneeye ·
Posted in Troubleshooting3 -
leclod ·
Posted in Operating Systems3 -
PatRed ·
Posted in New Builds and Planning6 -
3
2
StormBreakes ·
Posted in Build Logs1 -
5
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
