GPU temperature reaching up to 98° C under "regular" high loads with small OC
Solved by PhoenixFire22588,
19 minutes ago, ruzeno said:
Overclocking is a delicate balance between higher clock speeds and a stable voltage to handle it. Your voltage is likely too high and causing the fat temp spike
