help Motherboard that auto starts after power failure
Solved by BlueChinchillaEatingDorito,
3 minutes ago, mooli said:heyo kind folks! does anyone know a good budget motherboard that has the auto restart after power loss feature in the bios? Thanks in advance!
could be for either amd or intel.
Uhh... that's not something that's usually listed in technical specification lists... but I would guess most boards will support a similar feature under the power section within the BIOS. If you want, you can first choose the board, download the manual from the manufacturers' website and flip through it to see if its listed.
