Router with IGMP v3 and Gigabit Lan
SkyRyker
Hi all,
I'm looking for a 2nd router/switch for the living room to increase the wifi signal, this router would be connected via UTP cable straight from the ISP provided ONT, the Huawei HS8247W, then in the Living room this new router would serve as a switch to connect then to the ISP TvBox IPTV, so it would need support for IGMP v3, and then would also like to connect a Playstation via cable from this new router.
Any suggestion?
Thanks
EDIT: Europe based here
