Im 13yr old i need some help with my Budget gaming build: i need help on processor should i go with i5 9400f or Ryzen 5 3400g
Solved by RAM555789,
If only we could get Ryzen 5xxx CPUs in stock and stop having random price jumps in the 3xxx CPUs....the 2nd gen Ryzen's though are still a solid choice if you wanna upgrade in the future but I would rather get better performance now out of a 9th gen intel CPU and go for a bigger upgrade in the future.
