When running water cooling, which direction/option in my example is best?
Solved by Rybo,
I'd say more important in your case is getting air flowing through your case -- notably over your graphics card. For that, I'd put the AIO on the top and move the top fans to intake in the front. That way the air going over the graphics card isn't being constricted through the radiator/isn't slightly warmer for having done so. Whether your AIO is generating positive (pulling air in) or negative (pushing air out) pressure...is up to you.
