PC for fresh student (for a lot of adobe products)
Solved by Radium_Angel,
Just now, FishKebab_ said:okay ill try to go there today and list all parts. MB have 4 slots. ssd is some basic cheap one 128gb
so 1060 supposed to be replaced?
I'd leave the 1060 alone, it's find for Adobe products (I use one myself) but as has been said, more RAM will really help, and depending on budget, put the best CPU the motherboard will support into it, but it may not be cost effective.
By the way, your English is excellent, much better than my Polish!
