Search In
  • More options...
Find results that contain...
Find results in...
Thing that hold wire inside headset broke
Hey guys recently the thing surrounded by the red circle broke.For now I used some tape to hold it togheter but i was wondering if i can buy that plastic part anywhere
Thx in advance:)
2 minutes ago, Bartandroid123 said:
Whats the name of the headset?
Logitech g pro
You could try to make that part in 3D modeling software and then 3D print it.
I dont think you can buy that part
could you also send a photo of how exacly it broke
I already used same tape to put it togheter but i can try to describe.That part is held by 2 screws and it broke near both of them when i tried to put on the headset
More like snapped than broke
Well i guess if the tape works then let it be .couse nobody sells that part and im guessing that you dont own a 3D printer to design and fabricate your own.
