is there something better than B450 I AORUS PRO WIFI?
Solved by Guest,
If you're looking for a cheaper board, then yes The Giga B450-I pro is ok. Not sure how it would do with a 5800X though. Probably scary lol.
I have a ROG B450-I Gaming. Top notch board, bought mine used in an OC forum I frequent. I use it with a lidless 2700X and it handles it flawlessly. Blue tooth and wifi built in, which most boards don't come with the BT, and nice RGB. I think NewEgg has them around 165$ For me it was a good investment, I OCed on it a bit on the bench (sub zero) and then put it in my HTPC case in the living room. Sweet with that built in blue tooth makes file transfer from phone super easy.
