Desks deep enogh for a RVZ02 pc case?
Edward78
Looked on amazon, but most only look like they can handle a laptop.
MSI Performance Gaming AMD Ryzen 1st and 2nd Gen AM4 M.2 USB 3 DDR4 HDMI Display Port Mini-ITX Motherboard (B450I Gaming Plus AC), AMD Ryzen 7 2700 4.1 GHz, TEAMGROUP T-Force Vulcan Z DDR4 16GB (2 x 8GB) 3200MHz (PC4 25600) Ram, EVGA GeForce RTX 3060 Ti XC Gaming, 08G-P5-3663-KL, 8GB GDDR6, Metal Backplate, LHR
The RVZ02 is just under 15" on its longest side. What do you mean by "deep enough"? Most office desks are around two feet deep from the edge you're sitting at to opposite edge.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Ryzen 7 5800X3D | ASRock X570 PG Velocita | PowerColor Red Devil RX 6900 XT | 4x8GB Crucial Ballistix 3600mt/s CL16
Ok thanks.
-> Moved to Off Topic
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
12 hours ago, Edward78 said:
Ok thanks.
Make sure to quote people when replying to them so they know you responded (use the back arrow on the bottom of a post)
Either @piratemonkey or quote me when responding to me. I won't see otherwise
Put a reaction on my post if I helped
My privacy guide | Why my name is piratemonkey PSU Tier List Motherboard VRM Tier List
What I say is from experience and the internet, and may not be 100% correct
I personally dislike the cable management on this. I had a desk with the cable holes off in the corners like that and it's just nonsense. As for fitting your case— sure the depth of wider part of the L is greater than the depth of your PC case by about 4 inches. You could use a PC stand/under desk mount if you don't want it sitting on carpet or whatever your floor is. That lateral support beam might get in the way a bit, but maybe not a showstopper.
