We just leveled up HARDCORE - Fibre Networking Adventure
jakkuh_t
Over the years we've upgraded our networking many times, but we've always neglected one upgrade - fibre optics. Today that changes.
Buy 25G Fibre Transceivers:
From FS.com (Dell): https://rb.gy/obqekd
From FS.com (Mellanox): https://rb.gy/jb2upm
Buy Direct Attach 100G Cabling:
From FS.com: https://rb.gy/vym8b5
Buy Fibre Optic Cabling:
From Infinite Cables: https://lmg.gg/fibre
Check out Fibre Testing Equipment:
From Fluke: https://lmg.gg/flukefibre
widget.png?style=banner2
PC: 13900K, 32GB Trident Z5, AORUS 7900 XTX, 2TB SN850X, 1TB MP600, Win 11
NAS: Xeon W-2195, 64GB ECC, 180TB Storage, 1660 Ti, TrueNAS Scale
Fiber Optics.... Sigh
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
Ayy I actually watched a WAN show for once and this was there. Very cool.
PS: Your ingest stations are now 10 times faster than my home network rather than 4x faster.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
Pro Tech Tip for anyone doing this in their own office, Use single mode fibre.
I'm pretty sure in the next 12 months we will see the next video where they are trying to run 100gbit to workstations and have to re-run all this cable 🙂
Maybe off-topic but, since when does he have braces?
It's the first time I see them.
Nothing bad or whatever. Just surprising.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
Nah, multimode can do 400Gbit over 100m or so on OM5 and shorter distance on OM4 but I'm doubtful on it's ability to do 800Gb+ on current OM4 or OM5 fiber. OM3 can do 100Gbit just fine for 100m and while I agree single mode is more expensive up front the reason is to not have to rip and replace since singlemode has theoretically limitless bandwidth compared to OM5 for multimode which is a much worse endeavor when you're talking about tens of thousands of cables 😄
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
another thing I can't afford
Everyone, Creator初音ミク Hatsune Miku Google commercial.
Cameras: Main: Canon 70D - Secondary: Panasonic GX85 - Spare: Samsung ST68. - Action cams: GoPro Hero+, Akaso EK7000pro
Dead cameras: Nikion s4000, Canon XTi
Pc's
Dell optiplex 5050 (main) - i5-6500- 20GB ram -500gb samsung 970 evo  500gb WD blue HDD - dvd r/w
HP compaq 8300 prebuilt - Intel i5-3470 - 8GB ram - 500GB HDD - bluray drive
old windows 7 gaming desktop - Intel i5 2400 - lenovo CIH61M V:1.0 - 4GB ram - 1TB HDD - dual DVD r/w
main laptop acer e5 15 - Intel i3 7th gen - 16GB ram - 1TB HDD - dvd drive
school laptop lenovo 300e chromebook 2nd gen - Intel celeron - 4GB ram - 32GB SSD
audio mac- 2017 apple macbook air A1466 EMC 3178
Any questions? pm me.
#Muricaparrotgang
Yes and No. 100Gbit over muiltmode requires more then 2 strands (normally MTP-12 connections). 100Gbit over singlemode can use DWDM to run over the same 2 strands.
If they decided tomorrow to put 100gbit to one of the workstations, they would need to redo the cable. If they had single mode cable, they could just swap the SFP modules. The price difference between single and muiltmode is minimal (Sometimes its even cheaper).
Also their description on Muiltmode vs Single mode is a little misleading. Muiltimode does take multiple paths down the cable, but it doesn't do multiple wavelengths. Meaning only one signal can go in one direction on a single cable.
Singlemode allows you to put multiple distant wavelengths, each carrying different data, in both directions down the same cable.
Yes and No. 100Gbit over muiltmode requires more then 2 strands (normally MTP-12 connections). 100Gbit over single move can use DWDM to run over the same 2 strands.
Ah, not quite. There are 40/100Gbit BiDi optics for 100G 🙂
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/at-a-glance-c45-740242.pdf
Prior Build Log/PC:
2 minutes ago, Lurick said:
I have heard people working on this technology a few years ago but had thought it turned into vaperware and have never actually seen one in the wild. Do you know if they are they actually orderable? They don't appear in any of the supported matrixes.
Yup, I've got a few dozen of them right now 😄
I know the Cisco PID is QSFP-40/100-SRBD, I'll see if FS.com has any.
Prior Build Log/PC:
Nice Finnegan Speed and Marine shirt Jake.
I dont know where they got the price difference from? but we work mainly with singlemode (big ass halls with the average distance being 80m per hal, and 10 of them next to each other.) Singlemode cable is cheaper and modules are getting close to each other price wise.
And unlike what was said in this video splicing fiber is pretty much painless these days with good equiptment. I can be as fast as someone doing cat6-7.
8 minutes ago, Lurick said:
Yes, but distances drop quickly with higher speeds. Tho irl any small office will be fine.
Yah, they are limited to 100m tops over OM4 with those and I know the 400G ones are still up in the air right now but will probably be like 30m
Prior Build Log/PC:
Yeh the cost difference in price in singlemode v multimode isn't as mush as Linus makes out in the video. the biggest cots difference is in the splicing. we basically only use single mode fibre with 10 km modules at work and the cost is pretty much the same.
the main reason there is such a price difference in the enterprise space is just the vendors maintaining their profit margins. i had a quote from HPE recently for a 10 gB, 10 km module for $2k when I could get a module of the same quality for tens of dollars.
That and the ZR optics for like 40 to 120km are stupid expensive too
Prior Build Log/PC:
I bet they are just pretending that the OM4 is singlemode. I have seen people use singlemode SFP's on OM4 fiber for sub 50m before.
I got to mess with fiber for the first time last week.  Did a troubleshoot for the corporate job, we dont have IT on site - thats me lol, and found we had a bad SFP port on our network switches.  Switch port, fixed.  I look like a genius to the plebs (see also, non tech literate), its hilarious.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
All the fiber stuffed into the wall box there in the beginning is honestly a bit unsettling...
Considering that fiber tends to not like being bent at sharp angles, generally recommended to not have a bend radius sharper than about 2 inches. In wall boxes like these, I dubt that the bend radius even reaches 1 inch. Not saying that it "won't work", but it could be a source to potential problems.
I would have personally used a whisker box instead. Or a blank plate with a hole drilled in it for the protective hose. (And obviously do slack handling up in the drop ceiling, though it will probably fall down over time unless one has a cable restraint.)
That is just best practice. SM can easily be wrapped around a pencil without issues. Its done in the field by techs when working with live fiber in the many instances of lack of labeling, documentation or poorly managed. Every two wraps tend to give -2db of loss so you can monitor ports on the blade for loss without disrupting customer traffic and common.
MM is about the same. It does not damage the fiber, just introducing reflection. Bends, not arcs, are more of a concern
Wrapping a fiber around a pencil is something that "can" be done, but that doesn't mean that it is good for the fiber.
Long term it could cause issues. One of the main ones would be cracking of the plastic layer around the fiber and could lead to signal loss. Or delamination and creasing of it on the inside of the bend.
Best practice standards are a thing for a reason, and if one can avoid tight bends, then it is preferable.
In this situation I see little reason for just jamming the excess fiber into a tight box, when the drop ceiling has plenty of room for handling the slack.
I don't think you realize how malleable fiber is and its casing. It can stretch and retract up to a point but that is smaller than the dia of a pencil. Stretching is how fiber is made. Again arcs are not the problem, bends are and wrapping it around a dia equivalent to a pencil does not introduce a bend. If you are worried about the plastic cracking, unless you are dealing with un-shielded fiber that has been baking in the sun for some time, not going to happen without some serious pulling or fast kinks. Goes with the former above.
Best practices are not always based on hard limits but also are there because others have gotten tired of people bending, kinking and pulling causing damage to the fiber or excessive loss and introduced a practice well beyond when it will become a problem.
I have plenty of fiber splicing, tracing and troubleshooting under my belt and have ran into runs bent to such an extreme where there is loss but straightening its out and tossing it on an OTDR or the scope in the splicer with little to no damage. Fiber is a lot more robust that you are making it out to be, Linus piling it in the box, while bothers me from a sheer cable management view, is not the worst I have seen and is of no concern
@Lurick and @mynameisjuan,  Just out of curiosity, what fiber type are you guys recommending for new installs now days (both in the Office and in the DC)?
I have been recommending singlemode for all new installs everywhere for years now.
