Zotac gtx 1070 100% fan speed but fan rpm 0 yet fans are spinning slow.
19 hours ago, Mark Kaine said:yeah if DDU, reinstalling drivers and also reinstalling Afterburner doesn't fix it you may want to look into fan replacements.
But what happens if you set the default fancurve, ie don't use Afterburner at all, do the fans spin normally that then? That would be the first troubleshooting step.
I found the solution, I figured out it was the fan connection or the fans themselves, so I took apart my gpu, took the fans out, and cleaned them re applied oil to aid in spinning, there was alot of old grease built up and gunking it up, after the thorough cleaning, and some testing, I haven't ran into the issue yet, my fan speed is 79% following a curve on GPU tweak 3 doing 2950rpm solid. Thank you for help with the ddu and driver stuff, I did that incase it was an issue heard alot of problems with the recent nvidia driver
