Two network conections and splitting programms across them
Manley131
Hi, I would like to use two network connections at the same time.
The background is that I have connected my computer to the Internet via dLan (only 5 Mbits / s) but with low latency (approx. 10 ms), but on the other hand to my WiFi (approx. 40 Mbits / s) to stream or browse the web. With Wlan the latency is unfortunately around 100ms.
Therefore, I would like to split programs under Windows 10 over the two connections so that a stream can also run while playing. Until now i have to switch both conections.
Unfortunately I haven't found anything about it yet and hope you can help me!
Windows isn't great at doing this. Your probably better  off getting a router than can split the connections up. There are some hacky ways to do this in windows, but it can be annoying setting routes.
What you're looking for is load balancing but it will never really work like most people think. For example it will use one of the connection for downloading a file but you'll never be able to use both connection for it but in any case you want do that using hardware to get the best result.
